Re: 1987 Johnson 90hp alarms
I too had a steady alarm which was not an overheat problem....like Buck, my problem turned out to by faulty electronics in the oil tank sensor. I just decided to disconnect the oil tank alarm since I always check the oil level before heading out anyway.
If you want to check your oil tank sensor, just follow the wire from the oil tank into the engine...you will eventually come to a black sleeve like thing over the wire...it is protecting a scissor connector. Peel/slide the sleeve until the connector is exposed. Disconnect the wire, turn on key, if alarm doesn't sound, you problem was the oil tank sensor. If it still sounds, you faulty electronics are elsewhere.
Cheers.
