Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
It is a 1993 evinrude 30hp model # E30EETA when I turn is key all it does is chrip then nothing. I jump it and it started, so that would mean that my solinoid is bad. anna
If I understand the problem, it could be the ignition (start) switch, the neutral switch, the starter solenoid, or a bad connection.<br /><br />c/6<br /><br />Hooty
akillian,The high pitch chirp noise is likely a weak tone from your control box giving the initial alarm circuit confirmation signal when the key is turned on.Insure that your engine grounds are clean and tight.
OB, I have a good battery a good ground. when I check out volt. from the key switch to the solinoid is good, but from the solinoid to the started is dead. Could this mean is it bad. (solinoid) <br /><br />------------<br /><br />thank you anna K. <br /><br />ps thank you for helping me.
You can test solenoid by jumping from the large continuous 12 v cable on inlet side of solenoid to the small ignition terminal of solenoid and see if the starter engages.Be carefull around flywheel when performing this test.
