Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
1996 Johnson 115 hp.<br />I am having a tough time removing the impeller on the water pump. It seems to be stuck to the shaft. Any tricks for removing these?
Get some good pentetrating oil and soak down between impeller hub and shaft.Let sit for spell and see if you can tap around on impeller hub nearest shaft as possible and see if she'll work loose.
Walker,<br />Turning it clockwise while holding the shaft did the trick, it went click and I slid it right off.<br />Thanks a bunch, you saved me a whole lot of aggrivation.
