I need answers to the following basic questions about the cooling system on this motor.<br />1. Once it's sent up into the motor by the water pump/impeller, where does the water go that is expelled out of the exhaust port and the pee hole or telltale? <br />2. I assume that the water circulates thru the cooling jacket on the motor but I don't understand if the water expelled from these two outlets does different things (cools different parts of the motor?)and why there are two different outlets
