I have a 93 200 Ocean Pro that fried the #2 cyl with almost no warning while running along @ 5800rpm. All other cylinders OK exc #2,appeared to be detonation/preignition. Motor is recent rebuild possibly 50hrs. Prior to problem motor ran fine except for intermittantly having one cylinder drop off. Power pack was new and Compression was run, good on all 6. Upon dissasembly noticed one of the 6 flywheel magnets was loose and was not in its original position. Could this be a potential cause (i.e. changing the timing or causing problems in just that one cylinder?)
