evinrude headaches
myles carey
Re: evinrude headaches
try bypassing ignition switch.unplug the big red connecter, jump start the starter.
Joe Reeves
And the engine is what? Make, year, hp, electric start? We need a complete explanation if you want a complete reply my friend.
Joe Reeves
SimpleMan.... As Myles has stated, disconnect the large RED electrical plug at the engine. Remove the spark plugs. Rig up some kind of spark tester so that you can set a 7/16" spark gap. Crank the engine via a small jumper from the battery side of the starter solenoid to the small 3/8" nut terminal wire that engages the solenoid.<br /><br />The spark should jump that gap with a strong blue lightning like flame. If you now have spark, in all probability, the ignition switch has shorted out.<br /><br />To test the ignition switch, reconnect the RED electrical plug, remove the black/yellow wire from the back of the ignition switch. If Crank the engine via the ignition switch. If you still have spark, replace the ignition switch. Keep us informed.
simple man
well ive tried it all an still no fire the trigger is all thats left total so far is 500 bucks and trigger is $297 more itll be 97 more dollors than i gave for motor so theres where i am waiting for next weeks paycheck ill let yall know thanks for the help:)
