what year is my 10 hp johnson
skopav
I recently acquired a 10 hp johnson outboard model #QD -24b. I would like to know the year and if possible the fuel to oil ratio. Thanks :)
SeaMasterZ@aol.com
Re: what year is my 10 hp johnson
I run my early sixties OMC's at 32 to one, compromise between 24 to one and the oil skimpy 50-1 mix (I cant imagine running a motor at 100-1!)<br /><br />not that I am a parrot head, but THE JohnnyRude Guru on here said that the main reason those old motors are still around is cause they had plenty of lube running thru em
JB
With a friction bearing on the small end of the connecting rod 24:1 is the OMC specified fuel mix.<br /><br />See my answwer to your duplicate (boo!) post.
