Firing Order on the Distributor Cap
spookeev
I have a 1969 Johnson 115 HP V4, <br />Can anyone tell me the firing order on the Distributor Cap?<br /> My cap is not numbered, and I need to know which is number 1,2,3,4 <br />Thanks
Hooty
Re: Firing Order on the Distributor Cap
One is the top cylinder on the starboard side. Three is under it. Two is top port side.<br /><br />c/6<br /><br />Hooty
spookeev
Yes, I know the numbers on the engine side (as they are stamped) I need to know the order on the distributor cap side.(under the flywheel)<br />Thanks
Hooty
The firing order is 1-2-3-4 so see where the rotor is pointing when nr. one piston is at tdc. <br /><br />c/6<br /><br />Hooty
