Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
Need advice in taking out the bottom oil drain screw from the lower unit. Looks like the screw was set too hard the last time it was tightened and now the screw driver slot is worn out.
Take a small punch and put it against a corner of the screw that will make it turn counterclockwise...tap the punch until the screw turns...then remove it.<br /><br />TMD
