Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
hello jon here, i playd a little with fule and mix the motor/carb was orignaly made/set to run<br />100/1.. this proved deadly to the motor and everyone now runs 50/1.. if ur trolling u can risk<br />100/1 i personaly wouldnt.. but super gas with 50/1 standard outbaord oil works good. i can now count the rpms @ low idle..a carb rebuild over winter might be also in order,jon.. out
Yeah, both plugs are firing, and are brand new. I saw some places said to run 100:1 but I am running 50:1 and the motor runs super strong. Is a carburator rebuild a huge task?<br /><br />thanks guys.
my suggestion is 1- do a compression chk. if it<br />chks out ok .. put a OMC (not jobber) carb kit in there, 21.25 cdn u can walk in to the local dealer with carb .. i did and ask him to show<br />you.. it took 30/45min to redo mine. yes the dealer likes me, i tipd the 30 yr OMC vet 10.00
