Re: will my 1974 85hp v4 powerhead work on a 73 135hp
Sorry to hear about your rear end.<br /><br />Your 74 powerhead will bolt directly on the 73 midsection. The individual powerhead components are different and will not mix but the powerhead assembly will bolt up. Your 74 will bolt up to any V4 mid section from 73 to 76. It will also bolt to the 77 20" 85 and 115. Not the 77 140 mid section.<br /><br />If you use the 73 mid section and in the future need powerhead components (block, crank, rods or pistons) be sure to order them as a 1974. IE -- you cannot go by the model number on the 73 mid section.<br /><br />Good luck!
