setting timing pointer ------120/140 lv J/E
1. -- i dont have a piston stop, but i have not installed resurfaced heads yet.<br />so i can watch the movement of the piston to set pointer.<br />need to know what position the piston is in when touching piston stop.<br />-<br />A- piston/conrod are still in forward stroke just approaching TDC.<br /><br />B- piston/conrod are at TDC in between forward & downward stroke -rite at pivot point-<br /><br />C- piston/conrod are leaving TDC on down stroke.<br />--<br />my knowledge tells me its between A & B.<br />need to make sure while i have heads off to make timing and lync & sync adjustments correct.<br />-------------<br />2. -- while checking recirc. system i used the syringe to draw all the liquid from the lower bearing fitting.<br />-<br />before intake went on i sprayed everything down alot with the omc fogging spray, so should i inject strait 2cycle oil directly into upper and lower bearing fittings as a precaution before i start the motor or just leave as is with the fogging spray.
