markdenoyer
- Sep 1, 2003
- 2
Model# J70ELCDC<br /><br />I have little power out on the water. It seems as if my outboard is running on 2 cyls. The engine will run fine in the driveway but not on the water.<br /> Ignition: I have spark on all three spark plugs. <br /> Fuel: I have sprayed down the throats of the carbs and they seem to be clean. They were clean before I started. I have a water seperator/fuel filter just off of the inboard tank as well as a new filter on the power head itself. <br /> I closed off the top carb with a piece of cardboard as the engine was running and it stalled. Then I placed the cardboard over the lower carb the engine stalled. But when I closed off the middle carb the engine kept running. When I removed the cardboard from the middle carb fuel flowed Out the front of it.<br /> Could it be that the reed block behind the middle carb is stuck open? If the reed block is stuck open can you have a cylinder pressure? I am going to do a pressure check tomarrow when I buy the tool on the way home from work.<br /> Any suggestions all? Thank you.
