earlydayze
- Sep 2, 2003
- 1
Bought a small runabout w/1966 80 hp. Johnson electrashift. Have gotten shop manual (thanks to this forum). When I bought it someone had already rebuilt carb., new distrib.,new plugs,new coil, new silenoid, new gas lines. I have put in new impeller, cleaned out old gas and replaced with new, rebuilt fuel pump, new battery, Starter didn't sound healthy from the start and eventually burned up @ the neg. brush side. I took the starter to someone to rebuild( couldn't find brushes to fit because so old, had them made). This didn't help it did it again. Bought a used starter, did it again, fixed brushes and did it again. Does anyone know where the short may be coming from. Ground connection at battery fine, all readings at silenoid are fine, schematic suggests maybe ignition switch or a capacitor that comes in after gen. but I can't find where it goes from there.
