Re: water in fuel
What ever type of engine you have, you always have to have the oil right like it says in the manual for your type or engine at all times one time of not having the oil right could be a big problem. If the engine was running and all of a sudden it did not run and seized up. Maybe a lubrication problem. I would check to make sure that this is not a gear problem to, that would be easy to check. I don't know what type of engine this is exactly? So I leave it up to you find how to check that put in neutral and check it, if you have not already. If you get a chance Tell us more of what type of engine this is inboard or outboard 2 cyl or 4 etc.
