Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
warning horn burned out on omc control unit, I want to mount a differant horn/light on the console, this motor has vro. Does the purple wire supply the voltage and the brown the nessasary ground for differant warning sounds
Yes.The brown/tan is the sensor wire. horn should have seprate groung wire. The logic for the different alarn sound is in the horn, if you use an aftermarket horn the warning sound may be all the same.
