Re: VRO pump bad? running rich
An air leak in the fuel system is the most common culprit for making a VRO pump too much oil. Insert a piece of clear fuel line at the inlet fitting and run the motor at all speeds while looking for bubbles in the line. A vacuum gauge "teed" into the clear line should show a restriction of less than 4", 2.5 is ideal.
