Re: 115 Johnson under water
solittle, i think you meant to say most manufacturers reccomend flushing a motor after resurfacing a motor, as it is very hard to start a submerged motor. also something id like to point out, if your motor is submerged, your better off leaving it submerged if you dont have the stuff to fix it right away, example, dont pull the motor out of the water then drive to wally world to buy a gallon of 2 cycle to run through it. go get the oil first, believe it or not the motor is better off on the bottom, as most corrosion and rust will begin AFTER the motor is pulled from the bottom. if this sounds like crap to you then ask an expert, a diver who resurfaces wrecks, motors, and other structure. oh wait here i am HA
