I have try a lot and still the same, Changed sparks and wires, corrected fuel leaks, cleaned the carbs, syncro the carbs and still have a rough idle. The carbs has to screws on the side of the bowl for the jets orifices, when dissasemble, only the top screws had a small jet and nothing on the bottom one. After running the engine on idle I performed a spark plugs inspection and noticed a rich condition on them, I wonder if I'm missing the iddle jets on the carbs, where this jets are located, what are the jets numbers for runing at sea level? By leaning the carbs on the idle side would it improve? How do I do it? Any help would be apreciated.
