OMC Sea Drive Trim Will Not Hold
I have a 1983 1.6L Sea Drive on a 1984 19ft boat. <br /><br />When applying full throttle or sustaining speeds above idling, the trim leaks down immediately causing the boat to plain incorrectly. The problem has been diagnosed as the trim/tilt valve body needing replacement.<br /><br />Does anyone have any suggestions where I can find a valve body replacement, rebuild kit, or some type of work around that is economically feasible?<br /><br />Thanks, Skinny
clanton
Re: OMC Sea Drive Trim Will Not Hold
You have photo of pump?
Solittle
The OMC Shop Manual goes into great detail on those. I recommend that you get one + the Parts manual. I have a pair of 87s.
