I have a very nice Ranger Boat with a 1994 Evinrude Intruder 175 VRO. The boat has ran great since I have had it (4 years). Last fall I had it in for a motor tune up and lower unit lube inspection etc. Since it was in for service it seems to start and run great but after it runs for awhile (30 or so minutes) it has started smoking from the two exhaust ports next to the water pump visual indicator. It is using about 1/2 gallon of oil per 10 gallons of gas. Motor compression was 118 through 130 (as checked at the above mentioned check up). Has new plugs and run penz synth marine 2 cycle oil. I am running 93 octane but after I run these tanks out I will only use 87 (after reading many posts on this subject). Engine starts and runs great on ear muffs. It smokes alot cold but reduces to a "visible amount" only from the prop exhaust after warm up. When in the water and after the 30 minutes it seems to also start hard (alot more time to turn over). When I changed plugs they were wet with black oil/gas that would leave a small puddle under them if laid on their side. I have replaced the primer. I have read VRO or air leak is possible. I am just confused that it seems to start and run perfect and the problem only shows up after running awhile. What do the experts think???????
