jtexas
- Oct 13, 2003
- 8,646
My '80 evinrude 70 has a starting problem I believe is in the starter motor. Usually I hear the solenoid click when I turn the key. I can get the starter to engage if I loosen the cable connection to the starter & re-tighten. Then I noticed the stud is loose that the battery cable connects to. Question: how to remove the starter motor. It has two bolts holding it to the engine block - removed them no problem, but the dang motor wouldn't come off. Like it's glued in place or something. Should I just manhandle it or am I missing something?<br /><br />thanks a bunch,<br />jtw
