50 HP Evenrude Throttle Problems
Rick G
The engine runs great at full throttle but at half throttle it surges, slows etc.<br />The spark advancer lever moves back and forth at these throttle levels. I have taken the fly wheel off and set the sensors. No rubbing in this area. I have change the spring in the spark advance lever. <br /><br />Four mechanic have worked on it. Runs great at full throttle because the bolt holds the spark advance full ahead.<br /><br />Any ideas.
rwise
Re: 50 HP Evenrude Throttle Problems
Rick<br />Welcome to the board.<br />How about posting your model number for the guys and gals here, it will help them help you.<br />Richard
catfish1
rick, when you had the flywheel off did you check to see if the stator was swelled? happens alot! the stator will swell out a little, then as the flywheel turns, it will move the timing.<br />may not be the problem, but sure sounds like somethings movin it.
backdraft
Rick, beneath the magneto plate there is a plastic phenolic ring on a lot of evinrudes. As this wears, it fails to keep pressure on the plate that keeps it from rattling back and forth. This might solve your problem. nevjb
Rick G
Thanks folks. Great suggestions. I was aware of that ring and had thought about replacing it. Also, while I have the fly wheel off I will check for the swelling.<br /><br />Thanks so much. I'll let you know the outcome.
