chip51maker
- Nov 10, 2003
- 4
Recently I completely disassembled and bored out My 1987 150 Horsepower Evinrude Outboard Motor. I own a machine shop (not automotive) and I did all of the machine work Myself. The reason for the overhaul is because one piston was burnt as a result of overheating due to malfunctioning thermostats. <br /> The overhaul involved boring .020" oversize and reassembling with new Serria brand piston & ring sets, new rod bearings, new water pump and thermostats. The final bore size after honing gave Me .003"/.004" clearance on the pistons. I washed the cylinders with a strong soap & water mixture before final assembly. The block surface and the heads were machined to assure good headgasket sealing. The entire engine was squeaky clean before final assembly. I disabled the "VRO" and now must premix the fuel. The first tank that I ran thru the motor was mixed 25:1 and then I started running 50:1 after that.<br /> The problem is that ever since the overhaul My compression has been 30 PSI on all cylinders. The first compression check was before the initial startup and then I have checked it several times after a breakin period. I always check the compression with a screw in gage and the engine is hot and the throttle is in the WOT position.<br /> Will you please give me Your opinion about why I may have low compression and all of the factors that determine good compression. I thought that I covered all of My bases but apparently I left out something.
