150 60 degree intruder
bonitoman
How do you know if you have a glue seem leak on a 95 60 degree 150 intruder?
seahorse5
Re: 150 60 degree intruder
If you mean a leak where the crankcase halves are sealed together, there will be an oily wet spot in the leaky area. In severe cases, where the leak allows air intrusion into the crankcase and causing "lean spit" or backfires, you will see a flame or puff of smoke come out when the motor "pops".
bonitoman
Water is in the #1 cyl. Plug is clean. Where would I find this leak. I can pull the block and split the case no problem. What should I look for a crack?
clanton
I will have phone number in Clearwater Fl, for company that will pressure test and weld the block, Monday. I even forget the company name.
