vro 4 wire fuel pump
mo-jo
Happy new year guys i have a 4 wire vro fuelpump for a 85 v4 120 evinrude need to know where to get rebuild kit haveing trouble finding one :confused: :(
seahorse5
Re: vro 4 wire fuel pump
If the pump uses oval stainless steel retainers held in place with Torx screws that hold down the fuel inlet, pulse, and fuel outlet fittings, all the repair parts are available from your dealer.<br /><br />If you have an older pump, without the oval retainers, some of the newer parts will fit, such as the fuel pump diaphragm. First you will need a late model factory service manual to test the system for holding vacuum and pressure, and it will tell you what you will need to repair the pump.
OBJ
Or....just spend he bucks and get a new pump. I know it's good chunk of money but...IMHO...your much better off with a new up to date pump.<br /><br />Just my $.02 worth.
seahorse5
OB Jim is right, if you don't have the latest pump, then yours is probably not worth repairing. If it has the brown fuel outlet fitting, then replace it.
