Newbe here, Great Site, read many topics relating to my problem and Mr. Reeves has helped alot. He recommended I post here for additional input. Had 48 spl about 6 years only maint. plugs and lower unit lube change yearly. Rencently went out idles fine to about 2k rpm then engine misses so bad it feels like it will jump off transom. Joe informed my that my engine doesn't have the "slow" feature.<br />Not running hot, did test heat sensor it's seem ok. Thermostat clean and chamber not corroded. Joe informed me how to check the horn and it works when its grounded, doesn't come on when I turn on the key (will have to check that out further, may just run a test switch as the control box seems like it would be a pain to dissemble). The reason for all the over heat checking a local marine dealer said it was the "slow" feature. Had a 25 that did something similar and it was a bad/loose fuel line, I'm wondering perhaps the same here. Joe a clarification, you said to pump the fuel bulb with the fuel pump disconnected this would show a torn diaphram. And check by pumping bulb when engine starts to run badly will the fuel bypass the diaphram if they are not torn? I looked at them diaphram and they look ok just perhaps hardened?? If they are not torn is there a way to test? Any and all suggestions would be greatly appreciated. And sorry for the long post but just trying to give you the complete up to date.
