duckmon243
- Nov 16, 2003
- 3
i'm not getting any water flow out of the ports at the top of the lower unit. i've had the motor for 5-6 years and had a spray there before. just noticed lack of flow last fall while running motor in cold water. the only symptom i noticed was: after idling for some time the motor died then seemed like starter dragged when re-starting. (possibly the pistons starting to seize from being hot?) i've replaced the impeller, didn't help. then replaced the whole pump assembly (impeller, housing, liner etc)still no help. i've also blown air into the water tube that goes into the engine and sounds like air is returning through the exhaust. i would think that that is normal. i've backed my trailer down the ramp and tested in water after replacing parts and ran for 5 minutes or so and appears to run ok just no water flow. i can put my hand on the head and hold for few seconds and doesn't seem real hot. i don't have the manual for this motor but was told when i bought it than there was no thermostat. i live in Nebraska and it's been too cold to work on at the lake but i'm getting ready to give it another try soon. anybody have any ideas?
