Re: anodes
Hi Bayman,<br /><br />Could be that's what the mechanic meant.<br /><br />Still, the whole purpose of a sacificial anode is that it gets sacrificed! This happens fast in clear, warm, moving water, and slowly in cold, still water.<br /><br />If your 'zinc' isn't corroding away, either it's the wrong mix of metals for the water you're in, or it's oxidised - that is, it has a furry whitish surface. The oxidation will slow down its purpose. The answer is to attack it with a file until you hit clean 'zinc'.<br /><br />You WANT it to slowly vanish. If it isn't, then some other metal on your boat is vanishing instead. Not good!<br /><br />Zincs are cheap insurance when you cost out a prop or an outboard leg corroding unseen from the inside!
