Re: '83 Evinrude 15 tank vent.
No, sorry you can't do that. Yes 15020 is a 57, just like mine. One of the nipples is a fuel inlet and the other is an air outlet. Not sure where you're getting the third one at. it must be some sort of locking deal or something.
Your Yamaha tank would work fine, for one of the newer single line set ups and you changed the connector for OMC. The older twin line OMC set ups are very proprietary and nothing else will work with them. If you want to convert that old Fastwin to a single line set up, then you'll need to install a fuel pump and a new single line connector on the motor. Getting the old twin line tanks can be a bit tough and spendy, usually. I got lucky and found one for 10 bucks, but I was REAL lucky. All I had to do was replace the hose and that was quite a bit more than I spent on the tank.
If you have a Yamaha tank already, it may be just as well that you convert to a single line set up. What you'll need to do is buy a fuel pump for a 1960 or later 18hp and a bypass cover to mount it on and the connectors that go on the motor, by the tiller handle.
