I've had a ongoing problem with my1998 150 ocean pro running hot for about 3 years,will make a change ,like water pump,thermostat,work for a time or two,then overheats again.(horn sounds) It only overheats above 3/4 throttle,only have a guess of 100hrs on motor.This is what has been done to it,thermostats replaced,water pump replaced,heads removed,soaked and cleaned,power head removed,just had plastic bowls on carb replaced,leaking and would not go over 4100 rpm then would miss.just replaced plugs,no help,put thermosts in hot water with fish therm,they work.So running out of money on this motor,added alittle extra oil to gas to see if that would help. some people tell me to pull the thermostats out and run it full throttle and see if the horn goes off???will it hurt to try that?? oh yea and my pressure is about 7psi at idle and 20 to 27 at 3/4 to full throttle///running about 3 or 4 minutes and hot alarm goes off,also had sensor replaced 2 years ago, I think thats most every thing and would appreciate any advice you can give,thanks again
