Re: 115 HP JEY BOAT 4TH PISTON BURNING OUT
Since its hurt number 4 piston several times we can be assured that the cause of the problem is being transfered from rebuild to rebuild. Replacing the hurt piston is fixing the effect -- not the cause.<br /><br />If the motor still runs, now would be a good time for your tech to figure out whats causing the damage to the piston. It has to be changed anyway but troubleshooting now wont hurt the piston. You dont want to risk damaging another new piston.<br /><br />He needs to look for any type ignition problem like double firing, cross firing, flywheel center magnet loose, etc. Obviously going thru the carbs is a must also.
