I have a 1986 Grady Tourney with a 150 v6 vro. I connected a wire that should have been connected to the negative side of battery to the positive side
      . im gonna have to check out what the ground wire was for but essentially I connected 12v to the neg side of some components, I noticed the Temp gauge was going full scale when I did it, thats when I knew something was wrong. But now the tach is reading about 1000 rpm to high when cruising in the harbor(6-8 mph) when I know last year I cruise at 1500 and the tach is reading 2500 to 3000 rpm, impossible, I know my boat. if I bump the throttle up a bit, the reading goes down to 1500 but not for long and it jumps back to 2500 to 3000 again but no change in motor RPM. what could have happened? the REG/Rectifier? Also the temp gauge no longer works after that episode,could have fried that too, Its New this year and did work prior to my %$^% up. Thanks so much guys. BTW The ground wire I connected to pos side wasnt the main engine ground cable.
