I have a 1968 40 hp Johnson, When I started it this spring the engine felt hot to touch after about three minutes of running. So I replaced the water pump impeller & thermostat. I started the engine again and the engine still feels hot only after a few minutes of running. I then took out the thermostat cover and started the motor, water shoots out the thermostat housing. So I then removed the thermostat all together and restarted the engine. Still only after the boat is running for a few minutes the engine feels hot. <br /><br />Is this normal?? I used a 50 gal. barrel to submerge the engine. I believe the hot light doesn't work beacause of the age, is there any way of testing what the temperature of the engine cases? or did I miss something else? Or is every thing normal?
