levittownnick
 - Jul 2, 2003
 - 789
Johnson 150hp, '97 model J150EXEUE S/N G04209751<br />2 symptons. 1)When lowering the power tilt the engine is bouncing on the way down untill it reaches the trim pistons and then lowers normally. If the lower unit is hand held on the way down, the bouncing is eliminated. 2) When the By-Pass valve is open, the engine smoothly lowers but can't be manually raised. I have noticed some play on the port side of the pivot tube. (This problem was not evident last season.)<br /><br />I read the post from stinky2 on May 29, 2003.<br /><br />Thanks.
