Hi, I have an 03johnson 90 hp.I bought it 3 months ago and since new it misses between idle and 1600 rpm.I have taken it in several times and they have fixed thermostats, changed plugs and the last time adjusted carbs,set timing and adjusted linkages but still the same problem.If you take off slow or idle around the lake it shakes and stumbles also wen you run the engine and come to a stop it likes to idle around 1300 rpm for a few seconds.Before the carbs were adjusted the plugs would be wet when i pulled them out and now they come out dry with a light brown appearance.Any help would be greatly appreciated. Thanks in advance,Jeff
