Re: 1975 9.9 johnson spark leak
dgassy.....DO NOT use solid core wires.  There is to much resistance in solid core wires.  If the wires and boots from your dealer are arcing over, you may have missed the core wire when assembling.  The best thing to do is stripe a little of the spark plug wire, say 1/8" and press the spark plug coil, that's the coil with the barb to push through the wire, against the exposed wire and then push the barb through the center of the spark plug wire.<br /><br />When pushing the spark plug wire into the coil, I have found it advantagous to take a small sharp round punch and push it into the spark plug wire first to form a hole.  Also make sure the sharp end in the coil hole is centered.  If it is not centered, it can miss the center of the spark plug core.  <br /><br />Go back to the wires you got from the dealer and follow the above intstructions.<br /><br />And keep us posted as to your progress.....Thanks!
