Re: powerhead swap need finishing touches
Need more advice and suggestions. I got a 1985 rude 40hp vro(disconnected)electric remote. I swapped a good used powerhead and  every component  that was attached to it to my engine that had a blown cylinder. Took it out for first test run. Engine started easily after priming and a few cranks. Tried to make all necessary linkages and timing adjustment according to the manual. Engine idle fine and sound smooth. So far so good. Shifted into gear and started out at 2500rpm. No problem. Taking my time I got out of the harbor(thirty minutes)and I gradually open her up. Throttle up to 5000 rpm but I wasn't going fast. Then I pushed(forced)the throttle further and the boat just took off. I saw the tach hit 7000 and I backed it down to 5500rpm. I'm cruising now for a few minute @5500 thinking I fixed the problem and I fishing again until the engine started to "surge", tach needle wavering, engine power bucking. Get the picture. Double check all settings and tried different timing settings. No change. But before I came in I remember what you said and when I squeezed the primer bulb the power always return and engine would run smooth for a few minutes. I did this procedure all morning and it never failed.  Fuel filter always full. Power restored each timer after pumping bulb.<br />As suggested by several masters of Iboat here's what I did beforehand. Portable fuel tank w/fresh gas, 50:1 mix, can of Sea-Foam, new fuel line w/ bulb, new fuel hoses in engine compartment,and new spark plugs. I took apart four carbs to inspect and clean, using solvent and a thin wire to clear the passages and needles. Believe me, there nothing in those carbs now. I took apart one fuel pump for inspection and it look brand new, held vaccuum and manually I can pump fuel out. As I mention above, the coils and power pack and wiring etc. all came with this engine.<br />What scares me is this might be the same problem I had two years ago that might have lead to the damages to my original powerhead. I don't want to go through this again. How can this be? Original problem still there yet every component got inspected, replaced or swapped. Where or what did I miss? Caphank
