I have a 97 Evinrude Ocean Pro carbed 225 v6.<br /><br />When I try to start the engine cold it always starts right up (I always prime the bulb), but will not stay at an idle. I can keep the engine running by disenegaging the gears and giving it more gas. <br /><br />When I go to put it in gear to drive off it usually dies,,, I restart it, give it gas again and it works fine. As I itially start to plane and give it more gas it jerks like its not getting enough gas or air is in the line, as long as I have someone pump the bulb as I am giving it more throttle it evetually after about 15 seconds starts working fine. <br /><br />Now the weird part is after this ritual each time I go out the engine runs great, idles great with out any problems at all until the next time I take the boat out.<br /><br />Can someone please help or have any ideas? I have already replaced the primer bulb and the gas filter. I am having a problem figuring out what it is because it runs so great after this process.<br /><br />Thanks in advance for the help.<br />Eric
