I recently got this motor from a friend and it had been sitting up for about a year. I took the carb off and soaked as well as took the fuel pump apart (bad mistake). The motor will crank and run rough for about 10 seconds at w.o.t. then it catches, revs up and dies. I have primed the fuel system, cranked the motor and taken the fuel line loose at the pump going to the carb and no gas is coming thru at the pump. Should there be? Also after the motor dies, the primer bulb is spongy. Do I need carb work or new fuel pump? The model# is 5402B (any help with year model is needed also). Sorry for the long post, And thanks guys!
