Re: desperate -keep trying nothing works???
Hi Gain<br />The engine supplies presure to the tank, from the crank case via the air line. This is not a great deal of presure (I heard about 4 lbs) just enough to force fuel to the filter and fill the bowl of the carb. Once the bowl is full to the correct amount the float shuts off the flow. The main nozzle protrudes into the carb's venturi (the narrow place looking into the carb from the front. The other end of this main nozzle hangs down in the bowl. The reciprocating motion of the pistons creates vacuume and presure pulses. The vacuume pulses draw air into the venturi and past the nozzle, this draws fuel from the bowl. Now about your tank, I bet you have the model with the aluminium primer button on an aluminium shaft. Later models had a one piece plastic button. Here is the problem, The button on that shaft is supposed to rotate, the shaft is not. The buttons often become stuck to the shaft or fall off and are lost. This stuck or lost button situation allows torque to be applied to the shaft while priming (sort of a natural thumb motion). This twists the shaft loosening the nut on the bottom end. This causes the leak you describe. It would be wise to rebuild your tank and connector. How ever if just that nut has fallen off you can make a quickie repair just to tune your motor. These fuel systems are 50 yrs. old now, some have never had a repair or service. Once they get a good going over they will probly last another 50years. As I stated there are two models of these tanks. So there are two different diaphrams. Basicly both are exactly the same except the older model diaphram has a hole in it for the primer shaft and it costs more. This diaphram with the hole in it will not work on the newer tank with the plastic button. The good new is the newer,cheeper diaphram w/o the hole will work on an older tank ( you furnish the hole). If you have any questions just ask. Post your Email address and I will try and send you some usefull info for you motor. Read your clymer manual. Almost all the info I gave you is in there some where.
