Re: 8hp 86 'rude need fuel pump diagram
I did try that - engine wouldn't run at all after winter storage - so I got new fuel, and plugs, removed the carb, dissassembled and cleaned it all (no signs of any gummy stuff) dissassembled and reassembled the fuel pump, replaced lines and bulb to tank. Now it will start and idle well - but will only accelerate beyond that on the boat if the choke is fully out. Otherwise it will slow down and stall.<br />Compression and spark all good. Thanks for any ideas you may come up with.
