Hey guys... <br /><br />So, I tried to drop the lower unit on my 1958 Johnson 35hp Seahorse, but I got stuck. Now, I'm still working without a manual here, so let me apologize for that in advance...<br /><br />I took out the seven bolts that hold the housings together, and the lower unit dropped down about two inches. I could see the rod for the shift mechanism, what I assume is the drive shaft behind it, and a pipe (hose?) that I'm guessing moves water from the pump up to the engine. I took the access panel off of the side of the upper housing that allows one to reach a clamp on the shift rod. It looks like it may be brass(?) with two bolts running through it. I loosened these bolts, and now if I gently turn the LU back and forth I can see that the portion of the rod below the clamp twists while the portion above it does not. This leads me to believe that this is where the shift rod seperates, but even with the bolts loose, the LU wouldn't drop out. I didn't want to tug too much on it until I was sure nothing else was holding it up. <br /><br />From what I've read on here, the driveshaft is connected via a spline, correct? So that should just slide apart? And it looks like that hose/pipe just slides out of the water pump housing? Is this brass clamp on the shift rod the only thing holding me back? Is this the right place to seperate the shift mechanism? Any special trick to getting this clamp to let loose?<br /><br />Thanks a lot gentlemen...<br /><br />By the way, I'm in there to replace the impeller...
