Re: Johnson Outboard
Thank You for you're quick response. I tore-apart the entire lower end, cleaned, and resealed same when I was going through the engine. I used the "Marine grade" 90 weight gearlube. I did try applying forward force on the shifter when it was running to no avail. I had though about this problem of jumping out-of-gear when it first started happening. I kind of assumed that I'd hear a bit of gear crashing as seems logical during this type of event. However I realize this sound may have been dampened by being under water, exhaust noise, and not the least, the sound of my going Ohh-_ _ _ _!, every time it happened. I will tear into the lower end here soon, and look for any signs of trauma, metal particles, et all. I did, when reassembling the lower-end, check the machined surfaces for any signs of wear, tear, slop, play, galling, or rounding of the dogs leading edges where they mesh with the forward/reverse bevel gears. I guess I'll just shut-up now and get on with what may be an autopsy. Again Sir, Thank You for you're guidance!!! Ps, Have you ever noticed just how worthless the factory shop manuals are at attention to detail? I guess that's why God invented "Old-Salts/Sages" such as yourselves.<br /> Allen
