just wondering what it would take to install the quick start on my 1985-140?if thats even possible. I have an 1989-120.will those fit? if they do what are they?
You need the ignition from the 1989 including the flywheel. Yes, the flywheels are different. You are talking about outboards -- not Sea Drives, right?
yes outboards.when you say ignition,you mean powerpack,stator,rectifier?I know the flywheels are different,but is it ok to put a 120 flywheel on a 140.arent they weighted different?
same flywheel for the 120/140 for that year (89).<br />you will need everything<br />wiring harness<br />timing base<br />+ whay you have listed above.<br />why are you switching anyway?<br />-<br />the 1985 is a smaller bore than the 1988+.
