Lucky13ESP
- Jun 30, 2004
- 2
This engine is driving me crazy. Runs fine in the driveway with the flushing muffs on but when I get it to the lake, everything falls apart. Has a rough time idling in the water (idle speed is turned all the way up). When I can finally get the warm up lever down enough to get it into geer, it hesitates while accelerating. Either one of two things happen<br /><br />1) It revs up and dies if I just accelerate up to full.<br />2) If I work it slowly up, it sputters around 1/4 throttle and after sitting there a while, kicks it in a little and then I can accelerate to full.<br /><br />She runs fine once you get her open but the sputtering makes watersports a challenge. Again, it works fine with the muffs on. The only thing I can think of is in the drive the prop doesn't have to do any work. Plugs are clean, gas is 50:1, 87 octane (no ethanol), TC W3 oil, and the fuel filter is clean. Any advice is greatly appreciated. Thanks
