am I using the right plugs?
Scuda11
Just noticed something. When I first came here I thought my engine was a 1985, and got advice to get the QL77JC4 plugs. I think I then found out my engine was a 1983, which the sparkplug chart here on IBOATS says I should use a UL77V or QL16V Surface Gap<br /><br />Can you tell me what year my eng is, and if I am ok?<br /><br />Thanks!<br /><br />200 HP J5854641, model# J200TLCTS
Hooty
Re: am I using the right plugs?
It's a 1983 and it uses Champion QUL77V or UL77V plugs.<br /><br />c/6<br />Hooty
ob
The year is 1983 and according to my sources ,you got it right on the recommended sparkplugs.
Scuda11
Wow, I have been using the QL77JC4 is this a problem and should I switch to the UL77V or QL16V Surface Gap immediately??
ob
I don't know enough to advise on that.I'm not aware one way or the other whether you would have any interference issues with respect to the combustion chamber or piston heads.
nimmor
You probaly didn't damage anything, just not getting the maxium performance out of the motor. Put the right plugs in and gap them correctly. You should notice a better running engine.
Scuda11
Thanks allot guys, appreciate it.
