i have excellent top range motor runs good,checked compression,all 3 cylinders 100 then the last one was 85 changed the plugs too,the problem is when i move the throttle from start ,it bogs down if i move slowly it does not and will pick up speed like it should it does it every once in a while i also changed the water seperator filter too!!it seems to do it after the motor is warmed up,sometimes when it boggs down it will stall,when ever it bogs i move the throttle back then start again and it might not do it the second time,<br />please help!!the motor runs good starts good and once i get past the bog ,there is no loss of power at all<br />thanks in advance johnb
