I have a 1976 55hp Evenrude. It has me dumfounded as to why it will lose its spark. I had it in the shop and they got it running but told me they had not seen a problem like this in 15 years. It seems that if you remove the plugs and crank the engine it will produce spark. If you put the plugs back in you get no spark. The shop said that it needs to crank faster to spark when the plugs are in, so make sure I have a fully charged battery. So I have 2 batteries in series hooked up. Sure as heck it has died again with the same problem. Has anybody ran into such a problem and was able to find out the cause of this.
