1985 40 hp Evinrude choke?
Turtlelips
I just got this '85 40 hp evinrude and I cannot find the choke. Any ideas of where it is?<br /><br />Thanks in advance!
stairliftoheaven
Re: 1985 40 hp Evinrude choke?
choke is a solenoid valve located on throttle linkage side of engine. it has a small red lever on the side of it for manual operation. Its operated by pushing ignition key in while cranking. hope that helps
caphank
it also has a fast idle lever. Make sure you raise it during cold start. it opens up the throttle and advances the timing for easier starting.
McGR
The solenoid stairlift is talking about is actually and electric primer. On many later model OMC motors there is no choke, instead there is a primer which squirts fuel into the carb throats for cold starts.
Turtlelips
Thanks for the help. Now, the next problem I am having is...I just changed the VRO pump and the motor will crank and spark fine, but does not start. Any suggestions on what to do?
